Edited-Tag while merging but no visible changes
  • June 27, 2024
  • 5 replies
  • 145 views
Hello,
I struggle with merging currently a lot, because the preview marks a lot of components in the branch as edited, that should not be edited.
Both ways of reviewing them side by side or overlayed look exactly the same, but I still can´t figure our what changes have been made. Maybe a new layer name? changes in autolayout? As design System owner I should be aware of every change I merge.
This is really blocking me from merging and provides double work sometimes, because I will archive the branch and edit main instead. I will roll our branching-workflows for a whole company soon, this will be a major problem in two weeks. Can you help me with that?
ksn
  • June 28, 2024
Hey @Eva_Bandke - I can’t speak particularly for this since I’m not sure if there’s a bug or perhaps something very tiny being changed (or associated with a change) that you’re unaware of.
I do want to get you to someone on the support team to help you with reviewing your design system to get this sorted. Can you fill out this form and then let me know once you’ve done so? I’ll follow up with instructions after I hear from you.
  • June 28, 2024
Thank you for the answer, where can I find your support form?
ksn
  • June 28, 2024
Oop! That’s my fault – the link is here: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360005944714
Sorry about that! Let me know when it’s filed.
  • June 28, 2024
Thank you, I just sent the request to the support. Since it´s my customers Figma organisation I can´t share a link to his file, but he agrees with sharing a video, that I attached.
I don´t think it´s a bug, I assume there is no way to see changes, that are not visible or there is no change, but since it was clicked, it´s marked as “edited”.
ksn
  • June 28, 2024
Got it! I was able to locate your ticket and get it escalated.
A recording works fine! The one you attached to your case came through, so that will be reviewed.
Someone on the support team will get back to you as soon as possible. Ty for your patience 🙏🏼
