Drop Shadows Smart Animate
  • June 21, 2022
  • 5 replies
  • 1578 views
Mischu
Still no solution to the problem with shadow styles in smart animate?
I have 1 card with 2 states (default + hover)
The shadows are shadow styles. Elevation 8 and elevation 24
But on hover (smart animate) the shadow jumps about 100 px from it… This is not a feature, is it?
Thanks for any hint
Manuel_Barrio
I’m having similar problems but can’t find a solution or info. Other posts about this are closed with no resolution…
Robert_Kingslyn
I’m having the same issue with a shadow on a dropdown menu where it vastly exaggerates the shadow about 60 pixels in all directions around the entire menu. I’ve tried it with all the various smart animate options and the problem is the same. If I hide the shadow, then it works fine. As is, I can’t use smart animate on anything with a shadow.
Robert_Kingslyn
Here’s a screenshot comparison of what the regular shadow vs smart animate shadow looks like …
Amir_Nawed1
  • January 30, 2024
having the exact same issue. the shadows become big and occupies the whole frame during the smart animate duration.
same as the screenshot shared here
ksn
  • January 30, 2024
Hey @Amir_Nawed1 – since your response was to an older topic, your issue may be the same, but the method on fixing/addressing it may not be (since there have been updates to the platform since then).
I’m not familiar enough with shadows to give any direct suggestions on my end, so I recommend you get in touch with our support team. If you are able, they may ask you to share a copy of the file w/ the frames you’re working on to try and replicate or provide you instructions on how to fix: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
