An error occurred while loading the plugin environment
  • December 1, 2023
  • 13 replies
  • 3518 views
Taras_Savytskyi
Hi there!
I published a plugin and am waiting for the review.
When I try to launch the In-development version, it starts without any problems, but when I choose the published version (the one in the review), I get: An error occurred while loading the plugin environment.
At the same time, I have another plugin that was successfully published, and I can open both versions without any errors.
Is there something I’m doing wrong, or is it expected to return this error before the plugin is published to the community?
Thank you.
  • December 1, 2023
Have you tried restarting Figma? Stuff like this happens sometimes.
Taras_Savytskyi
Yeah, I tried several things, using Figma Beta and Figma Stable version of the app, restarting, logging out/in, restarting the machine, nothing seems to work. The problem persist.
  • December 1, 2023
In this case don’t worry about it, this is likely just a Figma bug (since it’s the environment failing and not your plugin)
Taras_Savytskyi
Thank you, Gleb!
I faced same problem in Figma while loading plugin. I work online, Do not use any app or Figma software. What can I do now?
  • December 13, 2023
If reloading Figma doesn’t work for you, reach out to Figma support.
I don’t reload page when plugin loading. I run and wait for that wedges. it is taking to load minimum 4minutes and then show that error.
cihad
  • December 31, 2023
I had the same problem. I’m worried whether it will pass the review or not.
  • January 1, 2024
This is an issue in the plugins engine, not in your plugin, so it should be good.
Abraham4
  • November 4, 2024
Hi Taras, I am having the same problem. My plugin works fine with the in-development version. But the Figma review team keeps getting errors. The published version does not open as well. Have you had a fix yet?
  • November 22, 2024
This might be because of the libraries you are using which might use components unavailable in the plugins VM. Perhaps your prod build config is faulty since even you can’t open the prod version. For the dev version, have you tried turning the dev VM on and running the plugin to investigate this?
Alexis.H
  • February 27, 2025
UP
I have the same issue for now more 4+ mounth and still no fix, even with a new draft i cant load any plugins.
Dev team look like they doesnt care at all about a major issue ? is figma dead ?
ehsan moradi
  • May 19, 2025
UP
I'm not sure if it's alive or dead, but there are a lot of bugs caused by the backend developers in Figma.
Let me help you out, my friend.
The main issue is that Cloudflare is being used without really knowing how it works ( by figma Dev team ).
If you use a VPN from another country, you might be able to get past the Cloudflare firewall and get the plugins working.
