Incorrect display of variables
  • May 3, 2024
  • 105 views
Karim7
When switching mods with varibles applied, are displayed incorrectly, on a dark theme it should be white and on a light theme it should be dark. The parameters themselves show everything correctly, but nothing changes on the object.
  • Figmate
  • May 6, 2024
Hi @Karim7, Thanks for getting in touch about switching between modes. I really appreciate you sharing the screenshot!
I tried testing it on my end, but I couldn’t replicate the issue you mentioned. It can be a bit challenging for our community to pinpoint the root cause of this specific problem without actually seeing the file and relevant variable settings.
Would you mind reaching out to our support team directly through the link below? They can take a closer look at this issue: https://help.figma.com/hc/en-us/requests/new
When contacting our support team, please make sure to provide the following information so they can investigate further:
  1. Please use your Figma account email address.
  2. A brief video recording that shows the issue when switching modes. Make sure the entire Figma window is visible, including the Properties and Layers Panel, and that the relevant layers are expanded.
  3. Share the direct links to the following files and add support-share@figma.com as an Editor to those files (this won’t affect your billing): The design file with the switching mode issue, and the library file containing the Variable Collections used in the file.
Hope it helps a bit! If I have misunderstood anything, please let us know. We also welcome any additional insights from our community, so if you have any, please feel free to jump in!
