Copy and Paste Properties not working for Auto Layout
  • September 13, 2023
  • 684 views
Jayfo
I noticed recently that copy + paste properties (from shortcut and menu) no longer works on Auto Layout elements.
e.g. I used to be able to copy use it to copy horizontal gap between items, but now I can only do this by manually entering the values.
Any help on this would be greatly appreciated, as it’s sloowwwwiinnnnng me down heaps.
Thanks community🙏
Best answer by Ryan_52
Hi @Jayfo I’ve tested copy / paste properties between Auto Layout elements but was unable to reproduce any issues. If you are still seeing an issue can you please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, share a short video reproducing the issue, include the links to an example file, and share it with support-share@figma.com so they can take a closer look.
Ryan_52
  • Technical Quality Specialist
jjcm
  • Figmate
  • February 19, 2025
Hey ​@Jayfo - just a small heads up, we’ll be rolling out a database migration and this fix will temporarily be down. You may see the functionality revert back to the previous state where copy/paste properties doesn’t transfer some variable values.
