Adding Stickys to Figma files
  • October 17, 2023
  • 315 views
dachan
Although the createSticky endpoint is not available in Figma files, you can manually copy a sticky from a FigJam file and paste it into a Figma file.
Does anyone know if there is a way to do this programatically to get around the limitation of the API?
  • October 17, 2023
There is no way
dachan
  • October 17, 2023
First thanks for being so helpful on these forums, it seems like you are basically carrying them.
Question for you, if there is no way then how is it possible you can just copy and paste it into a Figma file? Wouldn’t that be not possible either?
  • October 17, 2023
Plugin API just doesn’t have this capability. The user can do it because they can copy-paste between files. Plugins can’t work between files in the first place, let alone copy something from one file to another. The fact that Figma supports a node from FigJam doesn’t mean you can create that node in Figma.
