I'm trying to load the font but getting this error
  • March 14, 2024
  • 6 replies
  • 380 views
Neha_Gupta1
Error
Argument of type 'FontName | unique symbol' is not assignable to parameter of type 'FontName'. Type 'typeof figma.mixed' is not assignable to type 'FontName'.ts(2345)
Here’s my code.
  (async () => {
    const text = figma.createText()
    await figma.loadFontAsync(text.fontName)
    text.characters = link
tank666
  • March 14, 2024
There is no Plugin API bug here. This code works as expected and you can check it yourself (just run the plugin with this code). You are getting this Typescript error only in your IDE. I can’t tell you for sure because I don’t use Typescript, but it looks like you should follow the rules and syntax of that language.
user_of_figma
Usual arrow. I just used type conversion 🙂 as FontName
user_of_figma
I just used type conversion : ) as FontName
Neha_Gupta1
  • March 14, 2024
@tank666
First of all, I’m using the IDE recommended by Figma.
Secondly, I picked the code exactly from Figma’s API docs, I’m sure there’s no syntax error there.
Thirdly, I did run the plugin, it’s not working.
Neha_Gupta1
  • March 14, 2024
@user_of_figma_mikita
I ended up doing that and it worked. Thanks ❤️❤️
tank666
  • March 15, 2024
As I said, this code works as expected.
