How to create a correct relativeTransform for objects?
  • May 20, 2023
  • 9 replies
  • 1446 views
Alex_FG
Trying to apply several transformations in a row to a Figma object, including skew, and keeping the full working matrix (with correct scale values), how do I apply the final composite transformation?
I know that Figma objects don’t care about the scale in the relativeTransform and have to be resized using resize(). How do I adjust the transform to “remove” the scale but keep the correct rotation and especially skew?
In this picture I first scale then rotate, the points are transformed correctly, the rectangle and star are not. 😦
Here first I rotate then scale:
Here is skew. If that’s all I do, it works:
but as soon as I rotate the result, the objects and points do different things (the points are correct):
So, if I take an identity matrix and apply a bunch of transforms to it, how do I translate the final result to Figma objects?
  • May 20, 2023
Can you please share the code you used for these examples?
Alex_FG
  • May 20, 2023
Sure, it’s just basic transform code.
The transform function is
function applyTransform(obj, xform)
    // add to object's "total" transformation
    obj.xform = mulm3m3(obj.xform, xform);
    // apply only this transformation to the position (only for points)
    const p = mulv2m3(
        point(obj.x, obj.y),
        xform);
    obj.x = p.x;
    obj.y = p.y;
and the transforms are
applyTransform(obj, // move
    [[1, 0, x],
     [0, 1, y],
     [0, 0, 1]]);
applyTransform(obj, // scale
    [[sx, 0,  0],
     [0,  sy, 0],
     [0,  0,  1]]);
applyTransform(obj, // rotate
    [[ Math.cos(angle), Math.sin(angle), 0],
     [-Math.sin(angle), Math.cos(angle), 0],
     [ 0,               0,               1]]);
applyTransform(obj, // skew
    [[1,  sx, 0],
     [sy, 1,  0],
     [0,  0,  1]]);
Then, when it comes to actually updating the objects, I have two functions:
// figObj is the Figma object I'm updating, this is what is coming out wrong
// genObj is the generated object that I calculated
function setObjectTransform(figObj, genObj) // called for objects
    // make axis vectors == 1
    const scaleX = Math.sqrt(sqr(genObj.xform[0][0]) + sqr(genObj.xform[1][0]));
    const scaleY = Math.sqrt(sqr(genObj.xform[0][1]) + sqr(genObj.xform[1][1]));
    genObj.xform[0][0] /= scaleX;
    genObj.xform[1][0] /= scaleX;
    genObj.xform[0][1] /= scaleY;
    genObj.xform[1][1] /= scaleY;
    // do magic to make object transform correctly ???
    figObj.resizeWithoutConstraints(
        Math.max(0.01, genObj.width  * scaleX),
        Math.max(0.01, genObj.height * scaleY));
    figObj.relativeTransform =
        genObj.xform[0],
        genObj.xform[1]
function setPointTransform(figPoint, genPoint) // called for points
    figPoint.resizeWithoutConstraints(0.01, 0.01);
    figPoint.x = genPoint.x;
    figPoint.y = genPoint.y;
    // no transform here, points are already transformed at every step
    // so here I only care about their positions
mulm3m3() and mulv2m3() multiply vectors and matrices as their names imply.
So, every time I do a transformation, I update the object’s xform member (my own internal 3x3 matrix), but I also use just the current transformation to transform the object’s position.
On the Figma side, I use the transform if it’s an object and .x and .y if it’s a point. This way the points arrive correctly transformed and I can use them to test object transformation. Right now the result is not the same.
Maybe I’m not understanding the matrix thing correctly. Can’t I just have a complicated compound “final” transform applied to an untransformed object and have it do all the transformations in correct sequence?
Or, now that I think about it some more, do I have to keep an array of transformations, and then resize/transform/skew the object once for each transformation?
Alex_FG
  • May 20, 2023
An animation shows what is happening much better:
As you can see, the points are doing what they’re supposed to, while the object is not.
  • May 20, 2023
Thank you for the details! It seems like this is too complex for me to figure out, I hope someone smarter will be able to help. 🤓
I’m now also very curious about this thing: is this a plugin you are building? Or a widget, I guess? Looks very intriguing! I’d love to learn more if you can share the details.
Alex_FG
  • May 20, 2023
It’s my plugin Generator (https://www.figma.com/community/plugin/899028246731755335), I’ve always planned for it to have geometry nodes, just now getting around to work on them.
You can see how it works here: https://twitter.com/brainshift_/status/1653677256504475651
But I want to keep objects as themselves as much a possible (keep text editable etc), and the transformations are stumping me a bit. Hope someone can help. 🤷
  • May 20, 2023
Oh yes I’ve seen it when it was just released, it evolved quite a lot! 😍 Amazing work!
I’ve shared this post in the Figma Discord for visibility, hopefully someone can help.
Alex_FG
  • May 20, 2023
Thanks for the kind words! 😀
Alex_FG
  • May 22, 2023
Btw you can also work with text. 😉
twitter.com
  • May 22, 2023
Epic stuff!
