Wire Frame causing dull Image
  • February 21, 2024
  • 196 views
Aaliyah_Raghnal
This is so weird. When I put text or colors in a frame it goes dull but looks normal outside of it. I would love for it to not look dull in the frame so if anyone can help me
Aaliyah_Raghnal
see the image (and text) only shows outside wire frame
  • February 21, 2024
Hey @Aaliyah_Raghnal ,
This looks definitely odd! I can’t reproduce it on my end. Have you used the Ellipse tool? Is it happening in the browser, desktop app or both?
Would mind sharing a quick video recording (also showing the layer panel) to check the different steps you have done?
To cover some basics, I’d suggest you to clear out your cache then force quit and reopen Figma to see if that helps.
Mac
Use the Terminal app to clear the cache.
  1. Quit the Figma desktop app.
  2. Open the Terminal.app and enter the following command: rm -rf "$HOME/Library/Application Support/Figma/"{Desktop,DesktopProfile}
  3. Try opening the Figma desktop app again.
Windows
Run a command line from the Start menu.
  1. Close the Figma desktop app.
  2. Open the Start menu and paste the %APPDATA%\\Figma command. Press the Enter key to submit.
  3. In the window, delete the DesktopProfile folder.
  4. Launch the Figma desktop app again.
Let me know if this helps!
