How can i use `figma.viewport.scrollAndZoomIntoView()` with "BaseNode"?
  • July 7, 2023
  • 8 replies
  • 669 views
Lovefield1
const allNode = figma.root.findAll();
const target = figma.getNodeById(key);
let pageNode = target[0].parent;
if (pageNode.type == "SECTION") {
    pageNode = pageNode.parent;
figma.currentPage = pageNode;
figma.viewport.scrollAndZoomIntoView(target);
This is my code.
I have object key and figma.getNodeById(key) has return BaseNode.
So i want to change page and move screen to object location.
But scrollAndZoomIntoView() function is can’t use with BaseNode.
How can i do?
Best answer by tank666
figma.viewport.scrollAndZoomIntoView([BaseNode])
tank666
  • July 7, 2023
As an argument, this method requires an array of objects, not an object.
Lovefield1
  • July 7, 2023
Yes scrollAndZoomIntoView() function argument is Array. But use this is Error [...target].
Error : “TypeError: value is not iterable”
tank666
  • July 7, 2023
Why are you using the spread syntax?
Lovefield1
  • July 7, 2023
I want using scrollAndZoomIntoView() function, but this function argument is Array.
figma.getNodeById(key) is return “BaseNode”.
So how can i convert “BaseNode” to Array?
tank666
  • July 7, 2023
Just remove the spread syntax.
Lovefield1
  • July 7, 2023
Well, “BaseNode” object is can’t use to scrollAndZoomIntoView() function argument.
Is there really no way?
tank666
  • July 7, 2023
Lovefield1
  • July 7, 2023
Oh, Thanks so mush.
