Detach instance not working
  • May 11, 2024
  • 5 replies
  • 1079 views
Berkant
I’m experiencing an issue where detaching instances isn’t working in any component. Normally, we use command+option+b to do this, but currently, I’m unable to detach any component in any file. (I encountered this problem in a newly opened file, then checked my other files as well. It’s not appearing when I right-click anymore.)
  • May 13, 2024
Hey @Berkant, thanks for reaching out and sorry to hear this is happening!
I just checked on my MacBook in the app and using the browser, and things are working as expected. Are you able to share a link to your file, so we here in the community can take a closer look?
Berkant
  • May 17, 2024
Figma – 17 May 24
I created new file. Still I cant detach instance
  • May 17, 2024
Thanks, @Berkant!
Are you by any chance on a Starter plan?
The ability to detach instances is only available on paid plans. More info here:
Figma Learn - Help Center
Berkant
  • May 17, 2024
Yes, I am not on a paid plan and I used to be able to do it before. Do I need to switch to a paid plan now?
  • May 18, 2024
Thanks for confirming!
Our team just tried to repro on a starter team and detaching instances actually seemed to still work as expected. Where are you pulling your components from?
Can you also share edit access tp support-share@figma.com, so we can take a closer look at your file?
