Weird space issue only in preview
  • October 22, 2023
  • 594 views
Chloe17
Hello all, I have used two images with linear blend modes to make a seamless background design. The bottom image is on a dissolve feature to act as auto tab changing. In my document on the right, you cant see a random line appearing. I think the issue is with the bottom image. In preview you can see there looks to be a spacing issue as if I havent moved it up high enough. No matter what I try, I cant seem to figure it out. So far I have tried:
  • Moving images and changing layer hierarchy
  • Altering the gradient on both images / single image
Any help would be really appreciated, thank you. I am a beginner so please explain accordingly.
  • October 26, 2023
Hi there, thanks for reaching out! We want to make sure you get the help you need, and are connecting you with our support team to help you further. If you can share your file, our support team will be able to explain with detail what the problem is. Please feel to reach out via this form: https://help.figma.com/hc/en-us/requests/new
