Font appearing all distorted in my prototype
  • September 8, 2024
  • 15 replies
  • 376 views
Antonio19
Hi Figma Community,
I’m experiencing an issue with font rendering in my Figma prototype, and I could really use some help!
The font is Apple DS Gothic Neo (an embedded font)
The font looks fine when I’m designing, but when I view the prototype, the text appears distorted or uses a different font entirely. I’ve tried clearing my cache, restarting Figma, and even reinstalling the font, but the problem persists.
Has anyone else faced this issue before? Are there any specific settings I should check, or is there a workaround? I’d appreciate any advice or suggestions on how to resolve this!
Thanks in advance! 🙏
  • September 9, 2024
Hi there,
Thanks for reaching out. It sounds strange! I think you mean Apple SD Gothic Neo, and I tried to test it on my end. It seems to be working fine.
These kinds of strange font issues are nearly always caused by the use of conflicting font files across your team. This means that editors on a file are using different versions of the font with slightly different sizing or spacing which then affects the file each time it is opened by someone with a different version.
Our Help Center has more information about resolving this kind of issue: Manage conflicting fonts
We suggest that you have all editors remove these fonts if they are locally installed. Then please ask all editors to install the same version locally. After doing so you will need to restart Figma to serve the correct font version.
If this is affecting component appearance you can launch quick commands (cmd /) then use the “Regenerate all instances” tool to refresh all of your instances at the same time.
Can you try above? If the issue persists, could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new? Our support team will look into it.
Toku
Antonio19
  • September 9, 2024
Thanks for your response, Toku.
I’ve attached a screenshot showing what I encountered yesterday. Since this is my personal Figma project, I’m the sole editor of the file. I’m currently using this prototype for my portfolio.
The screenshot was taken directly from the prototype link in my browser. I’ve been working on this file for over a month, and I set the font correctly at the start. Up until now, I haven’t experienced any issues like this.
Any insights or suggestions would be greatly appreciated!
  • September 9, 2024
Thanks for sharing the screenshot! It definitely looks very strange. Could you share the proto file link with access to support-share@figma.com please? We want to test if this happens on our end. Adding the support link won’t impact your billing.
Toku
Antonio19
  • September 9, 2024
Thanks, Toku.
I just tried to write to support-share@figma.com but got a delivery failure notification from gmail.
Antonio19
  • September 9, 2024
Is there any other email address where i can send the link to?
Thanks in advance,
Antonio
  • September 10, 2024
Sorry for the unclear message. We want to ask you to add support-share@figma.com to your file as following. Then, please share the URL by choosing “Copy link”.
Hope this clarifies it!
Toku
Antonio19
  • September 25, 2024
Hello Toku, I keep experiencing the same issue. I noticed that it is mainly on Chrome.
I attach another screenshot to give you the idea of what it looks like.
In the meanwhile i have added support-share@figma.com (it seems i was only able to give it viewing rights, unsure that would be enough?). I look forward to hearing from you. Thanks
Hi there,
Thanks for flagging again! Could you share the file link please?
Toku
Antonio19
Hello Toku,
I think you shave received an invite to that address?
Is there a way to share the file link privately?
A
Nathanael_Foo
Hi there, is there an update on this? The exact thing is happening to me too. Thanks!
  • November 13, 2024
Hi there,
Unfortunately not at the moment. Could you submit a bug report detailing the steps that led to this issue? You can do so by following the link:
Figma Learn - Help Center
Thanks!
Toku
Storm
  • April 29, 2025
Let me know if you found the issue. We have a designer running into this, but no one else can replicate the issue
  • April 30, 2025
Hi ​@Storm
We haven’t… It’s hard to reproduce the issue, so could you submit a bug report detailing the steps that led to this issue? You can do so by following the link: https://help.figma.com/hc/en-us/articles/360041468234-Submit-a-bug-report
Thanks for your patience.
Toku
Miranda_Kay
  • June 9, 2025
I’m experiencing this issue as well. Any updates?
Anisa
  • July 16, 2025
It’s happening to me too, did anyone find a fix yet?
