Line problem when exporting to PDF
  • September 2, 2024
  • 4 replies
  • 381 views
Nolwenn_Cabasset
Hello,
I have a problem when exporting my frames to pdf. Some lines are disapearing and others are becoming thicker. I have to play zoom in and out to make them appear. But it is all good when i export in PNG. Do you know where this problem comes from?
ksn
  • September 2, 2024
Hey @Nolwenn_Cabasset - can you post a copy of the file you’re working with so I can do some testing?
I think what’s happening is that you’re exporting SVG’s with elements placed on sub-pixels – doing that can definitely be a factor in this behavior.
Nolwenn_Cabasset
David_Leman
  • September 18, 2024
The problems could be that some frames have clipped content. This could lead to frames not be printed through some PDF programs. I had this issue with printing svg in my PDF exports.
Nolwenn_Cabasset
Thank you very much for your answer! I will look into this
