Cant publish updated text styles
  • October 21, 2024
  • 154 views
Mateo2
Hey,
I recently updated some text styles and tried to publish them, but I keep encountering this error: “Unable to publish 6 changes to the Team Library.”
Also, neither of the affected text styles can be applied anymore.
Has anyone else faced this issue or know how to fix it?
Thank you 🙂
Best answer by y_toku
Hi there,
Thanks for reaching out. Do you have any “Invalid assets”? If so, you might be seeing them in the publish modal. Typically, invalid assets prevent the library from being published, so that could be the issue. If that’s the case, you’ll need to resolve these before you can publish.
Could you check if you have invalid assets? If the issue persists, could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new? Our support team will look into it.
Toku
  • October 23, 2024
Hi there,
Toku
Mateo2
  • October 23, 2024
Hey,
You were right, there was an invalid asset.
Thank you for your assistance!
