Some connections are not visible in Prototype mode
  • January 15, 2024
  • 8 replies
  • 933 views
So just when switching over to prototype from design, I see a bunch of connections I have already made between elements, but there are a large number not showing up as well. However when I click an element (that I have already applied an interaction to) it will then show its connection, and all the other connections on the workspace will vanish (reverting back when unclicked). I have looked all over (or am maybe just wording this poorly) as to why this is going on or why all connections are not visible at once. In the past, all connections were visible at once, having only a few of them show up makes double checking whether or not I made a connection very tedious.
Thanks for any help! <3
  • January 15, 2024
and here is a clicked element that has an existing interaction
  • January 16, 2024
Hi there! Thanks for your feedback.
This is an expected behaviour, when you click in a specific interaction, the other connections are not visible in order to highlight the one you select.
If you click then outside of the interactions, all connexion will appear again. Hope this is clear!
  • January 19, 2024
Thank you for the response, the top image I posted is my prototype with nothing clicked. I would say that its currently not showing at least 50-60% of the connections I have made. Most only show when the individual element is clicked. Is there no way to have all connections visible at once?
  • January 19, 2024
Here is a better visual of what I’m talking about, these images are of the same flow with no changes. The first was taken months ago, and the second one I just took a screenshot of. as you can see, there are a number of connections that are now hidden. Is there no way to toggle “show all connections”? or anything like that?
  • January 22, 2024
Hi Christopher,
Thanks for the details! To give some clarity, in order to avoid a jumble of connections, many connections will only show only as you deep select down to those layers — this is expected.
As explained, if these “hidden” connections still work but are just not visible in the canvas when you click outside of the interactions, this seems unexpected. In order to double check, please reach out to our technical quality team with a copy of your file so they can have a deeper look at it here: https://help.figma.com/hc/en-us/requests/new.
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com so they can take a closer look. Thank you!
  • August 12, 2024
Hi Celine
Has anything changed since the last post? I want to show all the designed connections for my portfolio, otherwise the prototype looks incomplete… Any ideas?
Thanks
Anna
  • August 14, 2024
Hey @Anna_K1, nothing has changed recently.
You can use the shortcut ⇧ ShiftE to toggle the visibility of any prototype connections. With this toggled, Figma will show any connections between frames, as well as the starting points for any flows.
More info on viewing prototype connections here:
Figma Learn - Help Center
  • August 19, 2024
That’s what I mean - showing “any connections” but not “all”
