Google Calendar Chrome extension - 'Log in with Figma' button doesn't do anything when clicked
  • September 11, 2023
  • 4 replies
  • 425 views
KailynNelsonTrove
I have the Figma<>Google Calendar extension installed, but when I try to ‘Log in with Figma’ while setting up or editing a Google Calendar meeting, but the button doesn’t do anything when clicked.
It’s worked for me before and been very useful; if I recall correctly, it’s done this to me before, and I’m not sure what resolved it.
Best answer by Ryan_52
Hi @KailynNelsonTrove can you check the add-ons in your Google Cal and try to remove and then re-install the Figma for Chrome extensions add on for Google Calendar. I would also suggest trying to clear your browser cache as see if that helps as well.
Ryan_52
  • Technical Quality Specialist
  • September 12, 2023
KailynNelsonTrove
That worked, thanks! Any idea why I have to remove & reinstall?
Ryan_52
  • September 16, 2023
I’m glad to hear that it worked for you! When you remove and reinstall, it essentially resets your browser settings and extensions, which can help resolve issues that might have occurred due to conflicts or outdated data.
Mahesh_Prajapati
It sounds like you’re experiencing an issue with the Figma <> Google Calendar extension where the ‘Log in with Figma’ button isn’t responding when clicked. Here are a few steps you can try to resolve this:
Clear Cache and Cookies: Sometimes, clearing your browser’s cache and cookies can resolve issues with extensions. Try clearing them and then restarting your browser.
Update the Extension: Ensure that both the Figma and Google Calendar extensions are up to date. Sometimes, outdated extensions can cause functionality issues.
Check Browser Compatibility: Verify that your browser is fully compatible with the extensions you’re using. Sometimes, certain browser updates or settings can affect extension behavior.
Disable Conflicting Extensions: Temporarily disable other extensions to see if they might be conflicting with the Figma <> Google Calendar extension.
Check Figma and Google Calendar Permissions: Make sure that the Figma extension has the necessary permissions to integrate with Google Calendar. You may need to check and adjust permissions in both Figma and Google Calendar settings.
Restart Computer: Sometimes, a simple restart of your computer can resolve temporary glitches with extensions.
If none of these steps resolve the issue, you might want to reach out to the support teams of both Figma and Google Calendar for further assistance. They may have specific troubleshooting steps or updates regarding this issue.
