Team library issue
  • September 30, 2024
  • 35 views
Help_Desk2
Having issues with team library. Created a component in design system file and it is not reflecting in the assets.
  • October 3, 2024
Hi there,
Thanks for reaching out. Have you published the file in which you created components? When you first create a style, component, or variable in a file, it is only accessible from that file. To make it available in other files, you need to publish it as a library.
Figma Learn - Help Center
If you’ve already published, could you share a screen recording or screenshots of where you’re unable to see it?
Toku
Help_Desk2
  • October 29, 2024
Hi,
Thank you very much for your suggestion. Yes, I have published it already. The issue issue is when I re-create the component and publish then it works fine. Don’t know the exact reason why that problem was persisting.
Aman
  • October 31, 2024
Thanks for getting back to me. If the issue persists after using “Repair component connections” via Actions, please feel free to submit a bug report.
You can open Actions by clicking the icon in the Figma Design toolbar or by using the shortcut Command + K on macOS or Control + K on Windows.
I hope it helps!
Toku
