Moving design file from Education folder to draft
  • December 12, 2024
  • 148 views
Julie_Philpott
Hi everyone, my education plan is about to expire, and I’m having trouble moving files from this folder to my personal draft folder. Does anyone have a tutorial or any suggestions?
  • December 13, 2024
Hi there,
Thanks for reaching out. To clarify the issue, can you try dragging the files to your Drafts folder?
Figma Learn - Help Center
If you want to keep your files on a Starter plan, here are a few things to keep in mind before expiring:
  • File limit: On the Starter plan, your team can have three FigJam files and three Figma Design files with a maximum of three pages per design file. You can invite as many people as you want to view or edit these files. If you have more than the allowed number of files in your team, Figma will prevent you from being able to edit your files. To keep editing those files, move them to your drafts or another team. Learn more about moving files →
  • Project limit: On a Starter plan, your team will have one project. If your team has more than one project, Figma will lock your team and prevent you from editing your files. To keep editing, you’ll need to reorganize your files and projects so they are under those limits. Learn more about moving projects and moving files →
If you want to continue using Figma on the free Starter team, we recommend that you do the following:
  • Move up to three Figma Design and three FigJam files into one project
  • Remove extra projects
  • Move files to another team or to your drafts
I hope this helps! Please let me know if you have more questions.
Toku
Julie_Philpott
Thank you, I figured it out.
