Question about the Figma Eyedropper tool!
  • September 10, 2024
  • 16 replies
  • 298 views
0909sang
Hello, I am a designer using Figma. When using the Eyedropper tool, the Color Picker shows RGB values like 255, 255, 255. Is there a way to set it to display HEX values, such as #ffffff, instead?
Leandro_Ramalho
I wonder why they changed it.
Before it was HEX, now they’ve changed it to RGB
Hey everyone, thanks for flagging it! We are not able to reproduce it on our end. @Leandro_Ramalho , please reach out directly to the support team with a copy of your file, so we can try to reproduce: here
Please use your Figma account email, include a link to the file, and add support-share@figma.com as an Editor, so they can take a closer look. Thank you!
@0909sang I see your ticket in the backend, I’ve escalated internally. Please also share the URL of the file and give access (add support-share@figma.com as an Editor) as mentioned. Thank you for your patience in the meantime 🙏
Kian
same, thought i had hit some shortcut to change it 🫠
rahend
  • Active Member
  • September 11, 2024
The last time I checked, the color picker was displaying hex values, but now it suddenly shows RGB instead of hex, and I’m not sure why. Does anyone know how to switch it back to hex?
phoebe_lim
I have the same issue. How can I fix it?
Hey everyone! After further investigation, we were able to reproduce the issue.
Our support team has submitted a bug report so our engineers can dive into it.
We’ll keep you in the loop with updates as soon as we have more information.
Thank you for your patience and understanding while we work on this!
Ioana_Ionescu
I have the same issue. Thanks for looking into it!
bzx
Same issue, it started to happen this Monday.
Lou2
You’re not alone—I’ve been experiencing this since the latest update as well and haven’t found a solution yet.
  • September 12, 2024
Hey everyone, we are glad to inform you that the issue is resolved now.
Please refresh / restart your app, and let us know if you are still having issues. Thank you!
rahend
  • Active Member
nice! so far it fixed! thank you
  • September 13, 2024
Hey @rahend , glad it is working now! Thank you for confirming.
John_Keese
  • November 27, 2024
I’m experiencing this again in Figma version 124.6.5
  • December 3, 2024
Hi there! Is it happening on browser, desktop app or both? Can you also tried to clear out the cache in the browser and/or desktop app to see if that helps?
(I’ve just had the same issue in the Desktop app with Figma version 124.6.5, and clear out the cache helps!)
If the issue still occurs after this workaround, please submit a bug report via this form for further investigation here. Thank you!
John_Keese
  • December 3, 2024
@Celine_Figma Yep, clearing the cache fixed it for me. Thanks!
  • December 3, 2024
Glad to hear you were able to fix it. Thanks for letting me know!
