Border variables only on custom sides, not to whole object
  • July 9, 2024
  • 155 views
KennLucas
In today’s fun with Figma…
Applying the variable for the border thickness of an accordion.
Cannot apply a border variable to the stroke. Even when you try to manually do it and change to a variable, no.
About halfway through this video, you see where I manually add a border, THEN change to the custom setting. Now I can apply the border thickness variant to individual sides.
Never to the whole border. But yes to individual sides.
KennLucas
  • July 9, 2024
Oh nice. IF you apply the border as custom to all sides using the variable…when you change the stroke back to ALL…then it shows that a variable is applied as the border thickness. The variable can be changed from that point. So not as an integer…but if you trick it in to being a variable. 🙄
Screenshot 2024-07-09 at 2.20.22 PM
