Disable shadow in Dark mode with variables
  • July 17, 2023
  • 5 replies
  • 846 views
Stanislav_Knopp
I have card components which use smadows in Light mode, but can I disable them in Dark mode using Variables? Can’t figure it out. Thanks 🙂
Best answer by Edwart
Hi @Stanislav_Knopp,
As Harrol mentioned it is not possible directly, but you can work with boolean properties for variants in combination with boolean variables per mode. Added screenshot for explanation.
Haroll
  • Active Member
  • July 17, 2023
Hi @Stanislav_Knopp
I don’t think it’s possible at the moment, but Figma plans to add support for variables in other places soon (some are described on the link bellow). You might need to wait a little bit
Figma Help Center
Edwart
  • July 17, 2023
Stanislav_Knopp
@Edwart Thank you very much 🙂
Trevor_Dupp
Great solution, unfortunately if you try to nest an instance of that card into another component that relationship gets stripped out.
As long as you don’t nest it - that solution will work 🙂
Emir3
  • November 28, 2024
Maybe this is outdated, but there is what I did.
I have used this method with variables to solve it the light/dark mode. So far it works really well.
