FigJam: Connectors break copied Frames Bug - WORKAROUND
  • December 19, 2023
  • 231 views
Basically I’m trying to use FigJam to do pseudo wireframing, show user flows like - If the user clicks x button it goes to y screen.
Yesterday, if I wanted to draw a connector between a button within a frame to another frame I would have to ctrl+click to get the connector to not auto-snap to the edge of the frame.
Today, it’s stopped working! Ctrl + click separates the layers within the frame, pushing them apart, then snaps the connector to the edge of the frame.
I’ve found one WORK AROUND: Locking the frame, then ctrl+click creating the connectors.
The fact that this worked yesterday but not today, makes it seem like a bug.
Now this next part is for the Figma devs - FigJam is so buggy it’s barely usable!
I have had so many troubles with FigJam over the last 24 hours I will be advising our team to never use it for another project again.
  • The fact that you can’t create connectors within a frame easily or consistently
  • The fact that replacing a frame does not work if the frame is nested within a section
  • The fact that I have to copy and replace frames
  • Plus many many more bugs
I have had to navigate so many workarounds to make this program usable it takes me an immense amount of time to get my work done.
  • December 20, 2023
Thanks for flagging!
We’ve passed this onto our FigJam team to investigate.
  • January 3, 2024
Hey there, thanks for your patience!
Our team has been trying to reproduce this behavior, but we haven’t been successful. What OS are you using?
