Figma Fails to Export All Selected Frames
  • April 18, 2024
  • 1820 views
Jules11
Everytime I select more than 2 frames lets say I select 6 and try to export them in Figma it will randomly only export like 2 of them. I have to individually go in and select frames at a time.
  • April 19, 2024
Hi there! Sorry to hear this is happening.
Hmm I can’t replicate on my end. I am able to export PNG, JPG, SVG and PDF with more than 6 frames.
Are you having this issue on desktop app, browser or both? Does it happen when you try to export to a specific format or this affects any type of formats?
Can you try first to force-quit Figma and start it again to see if that helps?
If the issue still persists, I’d recommend you to reach out directly to the support team: here
If possible please share a recording when you try to export the frames by including the exact steps you are carrying out. Be also sure to send the URL of the file , and add support-share@figma.com as an editor on this file so the support can try to replicate it. Note that users with @figma.com emails on your team do not count towards your billing. Thank you
Qreative_Cartel
Same thing was happening to me. Once you select all the frames you want to export make sure you press the “+” icon in the export section (bottom right) and then click the export button.
