Command + Option + C is not working, it's opening up code inspector
  • October 22, 2023
  • 220 views
Vaishali_Jain1
I am not able to copy text properties. Every time I press the combination, the dev inspector opens up. What can I do now to resolve this?
Ryan_52
  • Technical Quality Specialist
  • October 24, 2023
Hi @Vaishali_Jain1 I’ve checked this shortcut from my end here but was unable to recreate the issue. Can you try restarting your application. If you are using the browser, do you have any extensions installed?
