isMask property isn't working properly
  • September 5, 2024
  • 5 replies
  • 26 views
Tomer_Gabbai
Hi there,
We have a mask rectangle in a Figma file that is masking an image. However, when we fetch the node through the Plugin API, the isMask property returns false.
When we create a mask from scratch, it works as expected. But in this case, the property seems to return an incorrect value.
Are we missing something, or could this be a bug?
Thanks!
Tomer_Gabbai
Forgot the screenshot…
tank666
  • 4863 replies
  • September 5, 2024
Could you share a link to the example file?
Tomer_Gabbai
tank666
  • 4863 replies
  • September 5, 2024
I checked your file and the isMask property returns true for the node with id 0:1059.
Tomer_Gabbai
You’re right. Thanks for pointing that out!
