Discrepancies in Figma Library Analytics
  • February 16, 2024
  • 14 replies
  • 464 views
Tarun_Ottur
Hi Figma Community,
Upon looking at the usage data of our components within the Figma library analytics, I’ve noticed some discrepancies when delving into deeper levels of analysis.
Below, I’ve included a screenshot depicting these discrepancies at the instance level. You can observe that the total count displayed at the top doesn’t align with the sum of individual values.
Has anyone else encountered a similar issue? Any insights would be greatly appreciated.
Tarun.
Gayani_S
  • February 19, 2024
Hey @Tarun_Ottur, this looks interesting. I’ll need to check with the team if there is an explanation for this. I’ll update you once I get more information on this. Appreciate your patience!
Tarun_Ottur
  • February 21, 2024
Thanks, Gayani.
Gayani_S
  • February 21, 2024
Hey! So the team informed me that there should be a disclaimer at the bottom of that page that only the files one has access to are visible. So in your case there are a total of 13 files that use this component but you have only has access to 9 of those files. This works same for teams and Instances.
Hope this answers your question, let me know if not. Happy to help further.
Tarun_Ottur
  • February 21, 2024
Thanks for the response, Gayani. Does that mean the Design System team will have to get access to all the workspaces, teams, and files to get the complete statistics? Can there be a workaround for this since adding the design system team in all the private files might not be easy within the team.
We noticed that even the person with the Figma Organisation Admin account is seeing this discrepancy in the data. Shouldn’t the Admin given access to the entire data?
Gayani_S
  • February 21, 2024
These are good questions!
Let me double check this internally. Appreciate your patience!
Gayani_S
  • February 22, 2024
Hey @Tarun_Ottur, so I got the confirmation that this is how we respect privacy in the Organization. Even if someone is an admin, they don’t have permission to see the team’s content or files unless they explicitly join.
Also additionally, some files a user may not be able to see are other user’s drafts. We’ll never show the other user’s private drafts.
So you’re right you will need to “get access to all the workspaces, teams, and files” to see the statistics. However, you won’t be able to see when someone uses these components in their draft. There is not workaround for this at the moment.
Please let me know if this answers your question.
Tarun_Ottur
  • February 22, 2024
Hi @Gayani_S, thanks for sharing these in detail.
Ivan_Cross
Hi there! My team is only on a way to try this analytics feature.
So I’m curios is it possible to see data about external team using organisation Library?
Ex: Org Plan Team (A) shared Lib with Other Pro plan Team (B), is it possible to owner of Library see components usage (if he got access to file, like you discussed here)
Veneruso_Annie
Hi @Gayani_S , in a similar vein of analytics discrepancies, can you help me make sense of these numbers? If looking at total component insertions for the library, it’s around 25,000 for the past 30 day duration. However, the components called button, link, icons, in total are greater than that amount.
I assumed it could be because components like buttons and links and icons are used in other master components. Further looking on the view and explore analytics page, it says “nested components don’t count toward insertions” so it couldn’t be that.
Gayani_S
  • November 14, 2024
Hey @Veneruso_Annie, thank you for reaching out and sharing these insights! I understand how confusing it can be to see these discrepancies in component insertion data. I’ve reached out internally to get more clarity on this, and I’ll keep you updated as soon as I have more information.
Appreciate your patience as we dig into this!
Gayani_S
  • November 14, 2024
Hey @Veneruso_Annie! I reached out to the team and got some insight that may help clarify this.
It turns out the chart can be a bit tricky to interpret. Each point represents the number of insertions over the previous 7 days (weekly), so it’s showing about 20,000–25,000 insertions per week over the past 30 days—adding up to roughly 80k–100k total. The table at the bottom of the modal should show 30-day numbers that align with that total.
Could you let us know if you were viewing the chart as a rolling 30-day insertion total? And if possible, could you confirm where you’re pulling the total number from on the chart?
Thanks for your patience as we sort this out!
Veneruso_Annie
  • November 14, 2024
Thanks @Gayani_S, I understand. So the “Component insertions” chart when set to a duration of 30 days will display the last 30 days in weekly increments.
The data point on Nov 2, for example, that number is the total number of inserts for the period of Oct 26-Nov 2 (around 21,000).
The total I was referencing was if I added the button, link, and icons “Inserts (30 days)” amounts together, which confused me, as I thought the chart above was reflecting a 30 day value total and not a weekly value total.
Question: So currently, would it be right to assume that to find out the weekly component inserts by component name, it’s currently difficult to do? (Instead of “Inserts (30 days)” something like a “Inserts (7 days)”)
Gayani_S
  • November 19, 2024
Hey @Veneruso_Annie, let me double-check this internally with the team, so I can provide you with accurate information. I’ll get back to you as soon as I hear back.
Appreciate your patience in the meantime, and I’ll make sure to keep you updated!
Gayani_S
  • November 21, 2024
­Hey @Veneruso_Annie! The team gave me the following information:
If you’re on an Enterprise plan, the Library Analytics REST API (currently in public beta) does allow for week-by-week analysis.
Specifically, the /component/actions endpoint documented here would have the data you’re looking for: https://www.figma.com/developers/api#library-analytics.
Let me know if you have any further questions.
