Can select matching layers help me bulk add interactions?
  • March 13, 2024
  • 454 views
Ruoling_Wang
Thank you, team, for the fantastic new feature! It has significantly reduced my workload, and I’m planning to share it with my colleagues tomorrow.
However, I encountered a problem when I thought selecting matching layers would also help manage interactions, but it did not.
Here’s what happened:
  1. I created a dropdown and duplicated it across multiple frames.
  2. After several unrelated edits, I realized I had to design an open overlay for the dropdown and link them together.
  3. Using Command+Option+A, I selected the item across all frames.
  4. I attempted to drag the interaction to the target overlay.
  5. The interaction was not created for other layers.
  6. I tried again to modify the interaction in the side panel.
  7. Despite my efforts, only the layer I was working on had the interaction.
Is the feature I’m looking for not available, or am I doing something wrong? I appreciate your time and assistance!
Best answer by Ruoling_Wang
I got the answer myself. Click and drag could work for multi-editing interactions.
Ruoling_Wang
  • March 14, 2024
Ruoling_Wang
  • March 14, 2024
Ummm and Command+Option+A also works… Will check my previous laptop to see if I had updated Figma properly.
