Command-D not working for elements within component?
  • October 9, 2024
  • 53 views
Darren_Strange
Hello everyone.
I have a shared design system for my team to use. When they add a component from the shared design system to their project, the ability to duplicate an item (command-D) within that component doesn’t seem to work. Is this normal?
For example, I have a list of bullet points with a tick icon. Each text box and icon is grouped together, and I’m using auto layout to distribute them vertically. To add a new bullet point to list, I was using command-D to do this. But once it’s brought into a new project, command-d stops working and I can’t add a new bullet point.
Have I potentially set up the component wrong?
Any help most appreciated. 🙂
Nellya
  • October 9, 2024
It is normal. You can’t add or delete anything in component instance, only in main component.
You can add the some amount of bullet points in main component and hide/unhide it in instances in need.
Darren_Strange
  • October 9, 2024
Ah okay. Thank you for you reply.
Not too much of a problem - if I ‘detach instance’, then it works. I presume there is no real harm in doing that first.
Nellya
  • October 9, 2024
You will lost the connection to main component if you detach it, but if you don’t need it, it’s ok
