Conditional prototyping
  • September 13, 2023
  • 582 views
Hi,
I have created two interactive dropdown menus. The next step is that I want to create an interaction where the user navigates to a new frame after making specific selections in the dropdown menus.
Example:
IF
dropdown menu 1 = item A
AND
dropdown menu 2 = item B
THEN
navigate to frame 3
If anyone can guide me in the correct direction or provide me with a link which explains a similar issue, it would be much appreciated!
Osama_Turki
  • Active Member
what would trigger the navigation action to happen? is it after selecting both option or something similar to submit button?
regardless of the trigger, I would create two string variables Value1 and Value 2 (For the selected values of the two drop down menu) and those would be assigned by each dropdown selection (on click → set variable (Value1/Value2) to (X value/ Y value).
Then on the trigger I would set a conditional if Value1 = “X value” and Value2 = “Y value” then Navigate to “Frame”.
Thank you very much, this was exactly what I needed!
