Is it possible to split a text layer into two or more layers?
  • July 20, 2023
  • 8 replies
  • 1640 views
For example:
$19.99
/month
separate it into two layers where $19.99 is one layer and /month is another
Best answer by David
There are existing plugins which have this functionality. Here’s one example:
Figma
David
  • July 20, 2023
Figma
Im aware of that. I want know how to do it through the plugin api.
David
  • July 20, 2023
One of the currently available plugins has their source code available on GitHub. Take a look through there to see how they are handling it.
github.com
cool. thank you.
Vincent_Huss
  • Active Member
  • March 28, 2024
he’s only doing a split(‘\n’)
not handling :
  • the weird L-SEP char that appear if user does shift+ENTER (known issue)
  • natural text wrapping
anyone knows if the Figma API provides any sorts of info about the lines of text generated by the text engine ? i really can’t find anything
fengweiyao
  • September 10, 2024
@Vincent_Huss hi, do you have any solution now? i have the same issue.
Vincent_Huss
  • Active Member
  • September 11, 2024
no, i gave up on that feature,
it doesn’t seem like Figma provides any hook for that information 😕
maybe something to consider as a feature request @Figma_Product ?
=> for a text node : providing a list of bounding box for each lines
James_Yang
  • Figmate
There was another thread on something similar from earlier this year: Methods and/or Properties for Getting Dimensions of Lines of Text within Text Node?
