Theme switch with variables
  • March 7, 2024
  • 16 replies
  • 1054 views
flo_che
Hello, here is my problem:
I have 2 themes (A and B) for a button with icon and label text.
Depending on the chosen theme, the button automatically displays the A or B icon variant by using variables.
It works very well, except that if I apply an override color on the icon of theme A, this color resets if I apply theme B.
I would like this color to be preserved when I change themes.
Anyone have a solution for this?
Figma link here
ksn
  • March 11, 2024
Hey @flo_che I personally don’t have a rec. on a solution for this. I’m not very fluent when it comes to variables
I did check with the support team, and in general, this this should work, but would need to actually look at the file into the file to be sure 😔 It looked like the above you provided is just an example. Would you be willing to share a copy of the file you’re working with? If you can’t, no worries (also, please don’t post a direct link to a copy here to protect your work).
Thank you Kim, here is link to the editable Figma.
And some screenshots of the file
ksn
  • March 13, 2024
Thanks for this! I’m going to follow up with you via DM shortly with further instructions.
Hi Kim, I did not receive the request from support team. Is it possible to use my email address that you mentioned via DM ?
Nate_G
  • March 14, 2024
@flo_che I created an example file around button issues I’ve had in the past working with scaling+icons+modes, and how to fix them. Hoping this helps point you in the right direction.
Example Figma File
ksn
  • March 14, 2024
Sorry about that! I just PM’d you.
Thank you Nate for your help, your example file is very complete, but doesn’t solve my problem.
Nate_G
  • March 19, 2024
@Florent_Chevillard One idea is you could manage/change the icon color using color variables vs overides, which would preserve your colors when you switch modes.
Get Example File
Jan-Willem_van_Veelen
Did you find a working solution?
@Nate_G your example almost works for me, but I want to use a different color icon per button state (default, hover, pressed). So multiple variables per Theme for one icon.
In my case the icon color override did not work.
Nate_G
  • June 20, 2024
@Jan-Willem_van_Veelen One quick idea, you could try setting up color variables for each theme for your default, hover, pressed states and assigning those to the corresponding icons.
Thanks @Nate_G for the suggestion. I tried this set-up, but it seems that after Figma changes the icon-version, it does not apply the icon-color variable. Maybe applying the variables happens in the wrong order, so first color change, then icon-variant (that is then in it’s default color). I’ll keep digging into it and will let you know if/when I figure out a solution.
V_Verena
  • September 16, 2024
We currently have the same problem for our design system. Have you perhaps found a solution for this?
flo_che
Hello @V_Verena, unfortunately no, i didn’t found a solution for rhe moment. 😔
Dieter
  • September 17, 2024
Hi,
I am experiencing the same issue with our icon library. Some colour overwrites got ignored when another mode is applied. I created a file to illustrate our issue, where you can play around.
Figma color variable overwrite got ignored when changing modes.fig (94.1 KB)
ksn
  • September 18, 2024
Hey everyone - from what I understand on my end, these need to be reviewed by our support team on an individual basis. Apologies that I can’t assist further at this time.
I’d recommend anyone who is having issue with these inconsistencies file a ticket here: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
Dan_Flynn
  • October 2, 2024
I’m also having this issue, where, when you move a component from Theme A frame to Theme B frame, something such as a nested button component will revert to default state and doesn’t maintain any overrides (e.g. label text, rounded corners)
