Low quality image issue
  • October 22, 2023
  • 2078 views
Hi,
I have a question regarding image quality.
I am creating portfolio file for Behance and when I export frame from Figma quality looks good and then I want to add the same JPG to Figma back quality of the frame drops dramatically. What should I do in this case?
Anyone, please?
  • October 27, 2023
Hi there, thanks for reaching out! We display the image at its full available resolution in Figma, but when exporting, we recalculate the resolution to fit the frame size. Because the frame is set to a lower resolution, the image may appear more pixelated or of lower quality when viewed at greater than 100%. If you want a high-res image, you’ll need to use a larger frame or export with a multiplier. I hope this helps but please feel free to add or comment if you have further questions!
Toku
