HI, i am having problems when having both triggers (“Tap” and “While pressing”) assigned to one object. Like, imagine camera button, one tap - photo, long tap - switching to filming video.
Basically, as long as i am adding “While pressing” trigger, Figma recognise the usual tap as the “beginning” of a long tap and only “while pressing” trigger is being activated. Is there a solution for this?
In my opinion long press should have some delay, like if i am not lifting my finger after some certain amount of time, which exceeds the normal tap time, long press action is being triggered.
Thank you in advance!
Please search for existing topics before posting! Press 🔍 at the upper right to search.
Yeah, I’m having the same trouble
same problem here
I’ve had the same issue, you need to do the “navigate to” from the variant that the “while pressing” arrow leads to. Hope that helps 🙂
Thank you for reply Julia. But can you tell more, i dont quite understand the solution.
