Remove all auto-layout
  • May 14, 2024
  • 9 replies
  • 2700 views
Yoann1
Hi,
I like to work with auto-layouts but i work with Figma newbies and sometimes when they work with components i’ve worked on, they get overwhelmed.
Is there a quick way to remove every auto layout of all frames selected or contained in a frame ?
Because it can be very tedious to remove them one by one.
Best answer by zachshea
The Destroyer plugin does this and more!
Figma
  • May 14, 2024
Hi there, welcome to the community!
As a workaround, you can select all the auto-layout in your left panel for example, then use the shortcut: ⌥Option + ⇧Shift + A . Hope this helps!
zachshea
  • May 14, 2024
Figma
Yoann1
  • May 15, 2024
Thank you for your reply, but since you can’t select both the frame and the frames inside of it, I think it is still a bit of a painfull process
  • May 15, 2024
Thanks for the feedback, I understand the frustration. I will share it to the internal team.
(And also, thank you for sharing this plugin @zachshea !)
Yoann1
  • May 15, 2024
Thank you, i forgot to look into plugins !
Ofir_K
  • September 9, 2024
What is the combination over Windows?
Thanks
  • September 9, 2024
Hey @Ofir_K ,
For Windows, you can use this shortcut: Alt⇧ ShiftA.
Ofir_K
  • September 9, 2024
Thank you for your quick reply!
Kyle_Jackson
You can do this natively / without a plugin by selecting the parent frame then opening the actions menu (command/option + /) and typing in “Remove all auto layout”, press enter once the “Remove all auto layout” appears.
