Button icon wont change colour with instance swap
  • May 29, 2024
  • 168 views
For some reason, the arrow icon is fine (changes to white for hover state) but other icons dont change colour.
Each icon is set up as a separate component and a white icon colour variable has been used for the hover state button component.
Screenshots attached, as you can see when i change to the map marker icon it just changes to black on the hover state button.
  • 2544 replies
  • May 31, 2024
Hi there,
Thanks for reaching out. It looks like the override color is lost when you swap icons. Unfortunately, this could be a longstanding bug that our engineers are aware of and tracking.
While we unfortunately cannot provide an ETA on when this may be resolved, I can add your case to our open bug report to hopefully give this more visibility. In the interim, the best work around we can suggest is to manually override the color again after swapping instances.
If it is not the same issue, please reach out to the support team with details of your bug so our technical specialists can investigate: here
Thanks for your patience!
Toku
