Smart Animate Direction
  • July 30, 2024
  • 4 replies
  • 269 views
Samuel0216
Is there any way that you can change trajectory of smart animate animation?
For example, I created this card that you can access here:
https://www.figma.com/proto/OgbEnbpVrQH79TLMkaerST/Untitled?node-id=3-2&t=EiVU6T7hTypnpSfD-0&scaling=min-zoom&content-scaling=fixed&page-id=0%3A1
Usually, smart animate always use “blinking” animation. However, I want to change the animation that starts horizontally, like start from the left and ends to the right. Is it possible to create that kind of animation? Thank you in advance and I’m sorry if there are any grammatical errors.
Gayani_S
  • July 31, 2024
Hey @Samuel0216, thank you for reaching out!
I saw that you’ve posted your question twice, so I’ve closed out the other one,
I’m not able to access the file, can you invite support-share@figma.com with “can edit” permission so I can look into your file? Note that users with @figma.com emails on your team do not count towards your billing.
Also do you have an example of what you want to achieve so I can have a better understanding?
Gayani
Samuel0216
  • August 2, 2024
Thank you for replying my question! I was worried nobody would see my question. I’ve already added the email you sent so you can now see my project.
About the animation I wanted to create is a hovering button that goes from left to right, maybe this is the closest that I can interpret:
CSS Button Hover Effects | Left to Right Hover Effects | CSS Hover Effects @codehal ​|CSS Button Hover Effects | Left to Right Hover Effects | CSS Hover Effects @codehal ​|CSS Button Hover Effects | Left to Right Hover Effects | CSS Hover Effects @codehal ​
This is CSS-programmed, I don’t know if this animation can be created by Figma.
Gayani_S
  • August 2, 2024
Hey @Samuel0216, thanks! You have created a on hover action. I found a video demonstrating a loading effect Can you try to implement this on your button?
Creative Loading animation | Figma Interactive Components|Creative Loading animation | Figma Interactive Components
Let me know if you’re getting stuck on a step!
Samuel0216
  • August 5, 2024
This might be useful for my next to-do-list, but this isn’t exactly what I needed as of now, still thanks though!
I found the one that I needed here but I guess this animation cannot be implemented by just one frame. You can check ‘Button Hover Growth’ (I can’t seem to send the link somehow). By the looks of the steps attached beside of the project, it seems to be quite complicated. I do wonder if this can be applied to card with labels on it.
