Add outer frame to existing component
  • March 19, 2024
  • 1103 views
Hi! Did you find a workaround for that issue? I have exactly the same pain here
ksn
  • March 21, 2024
Hey @Juliana_Bravin! You responded to an old topic that is considered outdated (since things have changed). First, I’m going to break this off into a new topic and close the one replied on.
Can you drop more details on what you’re looking to achieve as well? Would be helpful to have more context on this.
Cesar_Riojas
I am looking for a similar solution. I have a component with multiple variants, but many of the color and text effects are applied to the parent frame of the component variant, but I would like to shift those effects and spacing to one hierarchal layer down.
I came here for the same reason, but was able to achieve what I wanted in a few steps (vs one), so figured I’d share.
In my case I had a component with a few variants that I wanted to wrap in additional frame.
To do this I:
  • Built a frame outside of my component, which I customizedcustomized as far as I could (autolayout, padding, etc)
  • Copied frame, then selected all variants of component, and pasted frame. (Note: If you plan to use “Fill” for the frame’s width or height, this is a good time to select that as this wasn’t an option until now and they’re still all selected.)
  • Then, I selected the stuff I wanted inside the frame in the first variant, and holding shift did a drag select on the rest of the variants to select the similar elements
  • With all the to-be-inside elements selected, I pulled up the layers panel, then dragged the selected items into the newly pasted wrapper frame. To my relief, Figma recognized that I wanted to perform the same relative action to all selected items and nested them within their respective wrapping frames.
I hope this helps! I’m still a bit new to the software, so if anyone has a better way, please chime in.
