How do i convert a figma file to psd layered file?
  • February 21, 2023
  • 8 replies
  • 26861 views
bndb
Hi, I would like to ask if there is any way to export my figma file to psd file that keeps the layers as I designed them in figma.
Thank you
Hello @bndb I have the same need… Have you solved this in any way?
Fernando_Lins
  • September 21, 2023
If you search for “Convert Figma to PSD” on Google, the first few results will link to an online tool that allows you to import a saved Figma file (.fig) and export it to PSD.
Alx
I’ve explored various online conversion tools in the past, but haven’t found one that maintains the layers accurately. I’m curious to know if there’s a manual method to transition between Figma and PSD?
Talita3
  • May 9, 2024
Hy @Alx “photopea” does it, but this conversion is not 100%
Tallulah1
  • September 19, 2024
thanks for your suggestion, it really helps!
btw, the font will be changed.
Zahra Jahani
  • February 26, 2025
Zahra Jahani
  • February 26, 2025
Hello, can you open this photo as a layer file for Photoshop.
Todd Morgan
  • May 6, 2025
Best way to do this without going online (which is scary to do if you are working on proprietary design for major client) is to export your file (whole or in sections) to PDF. Open PDF into AI. Ungroup and unclip clipping masks and save as AI file. Bring it into photoshop and it is now an editable SO layer. No need to go online. Text will be outline - but not a big deal you can cut/paste text from Fig to PSD.
