Variables names breaking why?
  • December 5, 2024
  • 7 replies
  • 86 views
Alfie_Matthews1
Hello,
I am setting up some new variables for my colour styles.
I use the naming conventions 100-900 but you can see in the attached screenshots the formatting is not visually correct.
Why is the second 0 so far away from the first?
Alf
Best answer by djv
Hey All, thank you for your patience!
Our variables team has launched a fix. Please refresh and let us know if you run into any further issues.
Manush_Kaliyath
Ferabite_Design_Co
I just finished adding my variables, everything was fine but somehow later that day everything was broken, the names look like this: “Larg e” and not “Large”…
Alfie_Matthews1
Since flagging the bug I have found a second that using the colour picker, within variables, my panel closes after click.
I cannot upload video for some reason
  • December 5, 2024
Hi everyone, thank you for flagging this!
We’ve escalated it to our internal team. We appreciate your patience as our engineering team looks into it, thank you 🙏
@Alfie_Matthews1 I can’t reproduce on my end for the colour picker, please reach out directly to the support team with your video, so our support team can investigate it further: here Thank you!
AntoineP
  • Active Member
  • December 5, 2024
Same issue here, the last letter in variable names is offset by a couple spaces
CamilaB
  • Active Member
  • December 5, 2024
If you make the name column smaller you’ll see that the part that “detaches” from the text also truncates separately. And if you make the column wider the space becomes larger.
  • December 5, 2024
