How do I find interactive elements in a design using figma plugin api ?
  • September 15, 2024
  • 55 views
MRIDUL1
I want to find all the interactive elements in a Figma design file. How do I do that ? I want to use the Figma plugin api for this ?
tank666
  • October 31, 2024
To find interactive elements in a file, you can use both the Plugin API and the REST API. In case of using the Plugin API, you need to check the reactions property on supported nodes; using the REST API—the interactions property.
Please see the following developer docs:
figma.com
https://www.figma.com/developers/api#frame-props
