This interaction must swap from a variant to another variant within the same component set
In the 1st image i am changing the value of a boolean variable to true and in the second image i am using that boolean to change the variant in other component but when i add a instance of the component in the frame it shows warning and doesn’t work.
Can someone tell me how i should approach it?
Best answer by Shivam_Saini1
What i was try to do was that I change from default to variant2 if a boolean variable was true.
I visited the related conversation before also but that didn’t help me out. However, now I have solved the switching by attaching a variable to property of Instance.
Thanks for your time.
