Logitech G Hub - Troubleshooting Profile Switch (Window 10)
  • November 6, 2024
  • 632 views
S_Hong
Hi everyone,
This is for anyone who wants a custom macro with Logitech G Hub but your profile switch doesn’t work for some reason.
  1. Find the location of your Figma.exe file by searching “Figma” in your start bar.
    Right click and then click open file location
  2. This will lead to a folder with Figma file and right click again and click “Properties”
  3. Go under Shortcut and find the Target property. Copy and paste this text but remove the last Figma.exe
Ex. Mine was C:\Users{username}\AppData\Local\Figma\app-124.5.5\Figma.exe so I deleted Figma.exe
  1. Launch Logitech G Hub and click MANAGE PROFILES
  2. Click ADD GAMES OR APPLICATION and paste the file path from Step 3.
    Click on the Figma.exe
lo
When I tried this few months back, Logitech G Hub couldn’t recognize Figma even though I added the .exe file.
It turns out, the file under \AppData\Local\Figma\Figma.exe doesn’t work. You have to add the Figma.exe inside a folder called app-124.X.X.
Now Logitech G Hub will properly recognize Figma as an app and context switch your profile when using Figma.
Hope this helps!
