Instance Swap Questions
  • March 14, 2024
  • 130 views
11
hello. The sentences are not smooth because I used a translator. Please understand.
  1. Two icons were converted into components.
  2. create component set
  3. create instance swap
  4. Swap triangle and rectangle
  5. The rectangle does not appear in blue, but in component color.
Why doesn’t the icon turn blue?
Best answer by Pavel_Kiselev
Check layer names inside each icon component, they should be identical
Pavel_Kiselev
  • March 14, 2024
  • March 14, 2024
It works!!! I struggled for about 4 hours to solve this. thank you so so much.
Pavel_Kiselev
You are very welcome mate
