Auto layout stop working when using an instance
  • March 21, 2023
  • 427 views
Hi there,
I have a component that I created. The auto layout works fine. When I select other, a text box appears and pushes the button and copy down. However when I start using an instance of the component, it doesn’t behave as expected. I got a video below:
Best answer by Celine_
Hi @Andrew_Chan1,
Hmm, not entirely sure on our side, but it looks like something is wrong in the order of operations.
Please submit a copy of the file with this prototype (if you are able) here for the Community or directly to our Support team here: https://help.figma.com/hc/en-us/requests/new. They can take a deeper dive into what’s causing this.
  • March 22, 2023
Hi @Andrew_Chan1,
Anderson1
  • April 17, 2024
Hi! I have the same problem. Did you get a solution?
