Text in resume pdf doesn't copy and paste correctly
  • March 5, 2024
  • 9 replies
  • 1749 views
Chasen
When I export my resume as a pdf, everything looks correct. However, when I try to copy and paste the text, many words are misspelled or have random characters in it. This is a big problem for when companies auto read my resume.
Chasen
  • March 5, 2024
  • March 5, 2024
Hey Chasen! Thanks for flagging this. Can you clarify if the issue (copy and paste the text) happens after you export the PDF from Figma? If so, we can investigate on our end.
(If this PDF was not exported from Figma, the issue would be from the PDF source instead of Figma.)
Chasen
  • March 5, 2024
Hi, yes the issue only occurs after exporting the pdf from Figma. Copy and pasting the text from inside Figma has no issues.
I mostly fixed it by moving the properties to a new frame and retyping some of the text, but a couple letters are still not correct.
  • March 8, 2024
Thank you for confirming! I’ve escalated internally to the engineering team to investigate the issue - while I cannot set an ETA yet for the fix at this time.
johntk22
  • March 8, 2024
Ensure that the font used in their username are properly included in the PDF file. When font are not attached then PDF viewer can change the font result in character are missing and misspelling.
  • March 8, 2024
Hi everyone! Thank you for sharing a workaround @johntk22!
To be transparent, we’re not actively investing in our PDF Export quality now, but it would be helpful to have a copy of your file so our engineering team can investigate further to implement a fix in the near future. It’s in our radar!
If you can’t share your file here, feel free to share a copy of your file by reaching out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Please use your Figma account email, include the link of this thread, a link to the file, and share it with support-share@figma.com as an “Editor”, so they can take a closer look. Thank you.
zora
  • April 27, 2024
I’ve experienced the same issue and managed to resolve it with this amazing plugin: https://www.figma.com/community/plugin/1255146474787882010/pdf-export-with-text-and-vector-objects
PDF also ends up being smaller which is neat.
James_John
  • September 2, 2024
Thanks for sharing! I’ve tried this plugin too and it works great
Marios
  • October 28, 2024
same problem. The plug-in suggested above allows for 5 free exports.
