Strokes included in layout not working
  • February 23, 2024
  • 5 replies
  • 1032 views
Hello everybody, just starting learning Figma and following the autolayer tutorial. Some how when I apply “Included in lay out” option on the avatars layout it doesn’t work. All the avatars have outside stroke. It’s maybe a bug or what am I doing wrong. Thank you
Best answer by Haroll
Hi @Gonzalo_Rivera
I may have a theory about it
TL;DR
Make the component 💠Avatar an auto layout and then change it strokes to Included in Advanced auto layout settings
Explaination
I cannot see how the component Avatar was built but I’m assuming that there is a rectangle inside it that contain both the image and the border, and that’s the problem.
What you’re trying to do is to tell the auto layout Avatars that you want the stroke of its children to be included in its frame size.
While there are strokes in you component, their width were not included in the component’s size and thus cannot be included in the Frame above. That’s why you need to included them in the 💠Avatar as mentioned in the TL;DR part
NB: As a general advice, you may want to let your main component (the one with this symbol : 💠) outside of your design and only use instance of it inside (the others with this symbol : 🔹). It will be easier to go back to it and it will prevent unwanted deletion
  • February 26, 2024
Hey there,
Thanks for reaching out. It seems there is not ongoing about this issue on our end. Could you please share the file link with view-access? We can take a closer look to investigate!
Thanks!
Toku
Haroll
  • Active Member
  • February 26, 2024
Hi @Gonzalo_Rivera
TL;DR
Explaination
Thanks a lot Haroll, that was the problem, made the Avatar component a layout and problem solved. Best wishes
Sabrina_Ham
I’m having a similar issue except in a component with variants. Adding auto layout to have strokes included at each variant and at the component level doesn’t seem to work
Aliaksei_Harbouski
Hey, everybody. I have a similar problem, the component doesn’t want to include stroke in layout. I tried rebuilding the component, nothing helps.
