Figma Relay plugin: Illegal character in query when updating UI
  • November 4, 2024
  • 4 replies
  • 303 views
Dave_Fraska
I’m getting a new error from the Relay plugin: “java.net.URISyntaxException: Illegal character in query at index 129: https://api.figma.com/v1/files//versions?page_size=30&column=date&secondary_column=default&after=2024-08-27 15:39:42 UTC&secondary_after=6508160513”
Anyone have any ideas what I could do to fix this?
My experience with the Relay plugin in general has not been great.
  • November 29, 2024
Hey there! Welcome to the community!
Are you referring to this third party plugin: https://www.figma.com/community/plugin/1041056822461507786/relay-for-figma ?
As all of our plugins are created by Community members and not Figma, you’ll need to reach out to the plugin’s creator for help using that plugin, or to report any problems.
You can find their support email on their page mentioned above.
The plugin’s creator will then report any bugs in Figma to us. I hope this helps!
Dave_Fraska
  • December 2, 2024
Yes that is the plugin I was referring to. I am aware that Figma did not directly develop the plugin. I assumed this forum was for anything related to Figma, including plugins. I had hoped that users of this forum would have a solution.
Is there a better place to ask the community about issues with plugins?
Unfortunately reaching out to the developer (Google) is difficult and has been unproductive. I left an issue report on their only support link (a bug tracker) months ago and no reply has been made.
Do you have a way of reporting plugins listed on your website that no longer work and do not appear to be maintained?
  • December 3, 2024
Hey @Dave_Fraska , thanks for your reply. Sorry to hear that you haven’t heard an update from the developer.
I’ve checked internally, the other option is to use the report option on the community’s plugin page. More instructions here: https://help.figma.com/hc/en-us/articles/12816896455447-Report-a-Community-resource-or-comment
Our team will review your report and take action if necessary.
Yes, you are correct, others in the community might also have any insights or solutions here. Let’s keep an eye on it!
Sneha Suryanarayana
Even i have been facing same issue, any solution has been found?
