Add Auto Layout isn't showing on right click menu prompt
  • April 12, 2024
  • 8 replies
  • 1756 views
I have two frames, both of which have auto layout applied to them. I’m trying to bring these frames together using auto layout, but when I right-click on my mouse to prompt the menu, only the option to remove auto layout is displayed. This was never an issue before. I was previously able to bring two frames together that had auto layout applied to them to build a component. However, now I’m only able to see the “remove auto layout” option when trying to bring both frames together.
I’m only able to do this now if I go to click on the main menu/objects/add auto layout.
I checked with my coworker with the same frames and Add Auto Layout shows up in the menu prompt when they have them selected and right click.
Best answer by Jose13
I just got an email saying the Figma engineers fixed the issue. I’m can now add auto layout with right click menu prompt.
  • April 12, 2024
Here is an screenshot of what my coworker sees compared to me.
Phil_Melito
Same thing happening to me. Very frustrating
Lenin
  • April 15, 2024
Also experiencing this issue. Very annoying
  • April 16, 2024
Hi there! Thanks for flagging this. Hmm this is odd that you don’t have the same settings than your co-worker. You should be able to add auto-layout in two frames.
I can’t replicate on my end:
Can you please reach out directly to the support with the screenshot and include a link to the file, and share it with support-share@figma.com, by filling this form here: https://help.figma.com/hc/en-us/requests/new
Our support team can investigate it further and try to replicate it. Please also make sure to use your Figma email account. Thank you!
olesia.nikolaevna12.03
I’m in the same boat. The auto layouts aren’t behaving like they used to in the app, but they’re working fine in the web version.
  • April 16, 2024
Hey there! Thank you also for flagging this. It works on my end both browser and desktop app but I may miss something 🤔.
As a first troubleshooting, can you try first to force-quit the app then clear out the cache (you can follow the steps here) to see if that helps?
If the issue still persists, please also reach out to the support team (please also mention that it only affects the desktop app, your laptop specs, and if is it happening in a specific file or not: here.
This will help our technical specialist to investigate it further. Thank you!
  • April 16, 2024
  • April 16, 2024
Thanks for the update and glad to hear it works on your end now!
For others, please refresh Figma to ensure that you are using the fixed version. If you continue to experience the issue, please let us know and we will flag it down for further investigation. Thank you
