Going back in version history doesn't retrieve deleted component analytics?
  • July 29, 2024
  • 41 views
Jason_Lockwood
A designer on my team did some select component refactor work. Instead of updating the master component they created a copy of the master component and made their updates on the copy. They deleted the original master component, and then the working branch was merged to the main library file.
Now in library analytics it is showing thatselect has zero inserts anywhere across the org.
Did deleting the master component, remove the analytics from the library? Even if the name is the same?
I’ve tried to go back in version history to before the merge, but the library still shows select as having zero inserts. (version history should capture the component analytics as well no?)
Can someone at Figma please explain if it is possible to retrieve the data?
